Hi
I have just upload my very firts plugin on vdj site.
Find the detail of what you will able to do with it.
https://virtualdj.com/blog/Deun-Deun/blog1355.html
Don't hesitate to send me any comment as soon as you will try it.
Denis
Denis
geposted Wed 18 May 05 @ 9:39 pm
This plugin is now on line. You can download it.
Try it and have fun !
geposted Wed 18 May 05 @ 11:40 pm
Very cool plugin Deun-Deun; congratulations.
Think for next release to go back to startpos or just after the part played. You can use the function "song_pos" for that. I'll send you some information about it.
geposted Thu 19 May 05 @ 7:46 am
AMAZING !!!!!!
I LOVE THIS PLUGIN!!! thanx a lot!!!!
geposted Mon 23 May 05 @ 1:53 am
is it possible to make it run over more that 4 beats??
geposted Mon 23 May 05 @ 2:18 am
I made a new one. You can select now how you want to insert the effect like reverse and overpan.
Unfortunately, you can not use it run over that 4 beats.... at the moment :)
From yesterday evening, you can dowload it from the VDJ site.
geposted Mon 23 May 05 @ 9:40 am
omg...this plug in is awesome!!!!
What do teh numbers correspond to on the bottom......1022...4011...etc.....what do those mean....for now i've just been playing around until i get a cool effect....but if i actually knew what thsoe meant i think i would eb able to come up with even cooler patterns...
Thanks,
NAW-T-BOY
Thanks,
NAW-T-BOY
geposted Mon 23 May 05 @ 6:22 pm
press his name, and you can see detailed description of all settings in his blog ;)
AND I WANT IT TO BE FOR MORE THAN 4 BEATS AS AN OPTION ;))))))))))) PLEASE!! ;)))) with sugar on top! ;) loool
geposted Mon 23 May 05 @ 6:25 pm
dj-in-norway
How many beats do you want: 4 and a half :)
precise your request: you mean the same sample of 4 beats but in loop? sample overloop ?????....
geposted Tue 24 May 05 @ 1:05 pm
4 & 8 :)
no big deal, but think it would be cool if there was an option for 4 and 8 beats
geposted Tue 24 May 05 @ 1:09 pm
if possible.. and sounding good...
it sounds GREAT now !! ;) just to make it last a bit longer if I want... like 8 beats (overloop, or real 8 beats)
geposted Tue 24 May 05 @ 1:10 pm
Maybe, 8 beats would be possible, but I mean 4 beats x2
I will look if I can add the option following : "without stopping the plug automatically after 4 beats"
Does my suggestion sound good for you?
geposted Tue 24 May 05 @ 1:34 pm
Very good!! ;)
And damn.... your plugin is just AWESOME! :) thanx for developing it... :)
geposted Tue 24 May 05 @ 2:37 pm
Yes 4 by 4 for should be very good.
geposted Tue 24 May 05 @ 6:12 pm
Hello
I really enjoy this plufin but it is limited to 4 beats rythm. The must will be to have it for unlimited beats. Just pushing to the shortcut to stop it and not an automatic stop at the 4th beat.
If you read this Deun Deun it will be great.
Very good work Deun Deun !
geposted Thu 26 May 05 @ 2:31 pm
Great plugin!
MS
MS
geposted Fri 27 May 05 @ 7:04 pm
Hi everybody
Next update of the plugin will allow to use the effect like a loop.
In this case, you will have to stop it manually
geposted Fri 27 May 05 @ 10:28 pm
That's much better; this way we use Fade during Shaker beats treatment and we start another track on the other deck; cool mixing effect.
geposted Sat 28 May 05 @ 10:22 am
nice!! ;) look forward to that update...
thanx!!
thanx!!
geposted Sat 28 May 05 @ 2:42 pm
is there anyway you can save the setting that you madeother then the regular setting when you get it mines keep setting back for the different plugins you think?
geposted Fri 19 Dec 08 @ 5:07 pm
