Hey everyone. I just bought an NS7 and started my virtualdj trial before I buy to make sure it works.
All the mapping seems to work fine. I do have an issue though.
When a song on Deck A is playing and I load a song on Deck or vice versa, the song on A breaks up a little bit. Only for the first couple seconds when it's loading. I do have the platters set to vinyl (spinning). I tried settting it to CD and it helped a little bit but still hear it sometimes.
Sometimes I hear it randomly when I'm playing too. I get a little static or can hear a little break up. I do use Keylock which I read some people have found it to be that. I hear it sometimes with and without.
I hear it through the Cue, Booth, and Master Out.
In VDJ settings, I have under Performance, the slider on the 2nd notch from the left, Sound Card Latency is Auto, and both safe mode and overclock are unchecked. (As I was typing, I realized I haven't tried to turn the Preset slider down to the 1st notch (fastest) yet. Will try after I post.)
In the ASIO config I have tried a couple settings, 128 samples, 512 samples.
Most of my trial and error has been from reading on this forum.
I have updated the NS7 Firmware to 1.03 I believe it is (came with 64bit drivers.) I also read that 64bit could be an issue. I made a partition on my laptop and put 32bit Windows 7 on to try it but getting an error installing the driver, 0x000006 or something.
I just bought an ASUS G72GX Laptop which I'm using. Specs are good so I don't think it's a speed issue although I see the CPU increase when the songs are loading to about 80%. It sits I would say around 20-25% normally when playing.
Intel P8700 2.53ghz Core 2 Duo
6GB DDR2
GTX 260M
http://www.bestbuy.com/site/Asus+-+Laptop+with+Intel%26%23174%3B+Core%26%23153%3B2+Duo+Processor+-+Black/9556125.p?id=1218124208054&skuId=9556125&st=g72gx&cp=1&lp=1
I have an opportunity to start working at a local bar that my friend's parents own and would love to have my NS7/VDJ setup. I just have to cure this audio glitch and I will purchase VDJ and have a great setup.
Thank you to these forums for all your help. I have done a lot of searching and reading on here. It's great!
6GB DDR2
GTX 260M
geposted Mon 01 Mar 10 @ 5:03 pm
WOW NICE NOTEBOOK, HAVE YOU ATTEMPTED TO DO VIDEO? IM JUST CURIOUS AND I MEAN FOR A WHOLE NIGHT NOT JUST A FEW VIDEOS HERE OR THERE..
jamm
GOOD LUCK
jamm
GOOD LUCK
geposted Mon 01 Mar 10 @ 7:17 pm
Stay on the 512 samples and check the Overclock to see if that helps ?
geposted Mon 01 Mar 10 @ 8:07 pm
i have similar issues [ and a few others] ...but cant say no one has been able to help me...ive been using itch since...which is sad cause i want it to work with vdj!...
geposted Mon 01 Mar 10 @ 11:28 pm
what i do when loading a song or vid i turn off the platter side u loading too or both and u will not get sound disturtion after it load u can turn platter back on
geposted Tue 02 Mar 10 @ 6:17 pm
that dont work for me...i wonder if it works for thauch?
im really starting to believe im cursed...4 laptops for trials n i got nothing working
geposted Tue 02 Mar 10 @ 7:13 pm
So far I've had some better luck with these settings:
ASIO Config, 128 samples
Performance tab:
Slider all the way to the left
Auto
Both boxes unchecked.
How do you turn the platters off without going into the settings?
Performance tab:
Auto
geposted Tue 02 Mar 10 @ 11:10 pm
I'm going to futz around with my Win 7 32bit install again to see.
** I have not tried videos yet because I'm mastering the beat mixing. When I get that far, I'll work on some video. I'm sure my computer can handle it.
I also built Rack Mount PC which I was going to put in a case with the amps.
Core 2 Duo 2.13ghz
4GB DDR2
GT220 Card 512MB w/HDMI
Win7 32 Bit
This is what I was using to learn before I got this laptop. If I recall, I had similar issues. I think that pc should be fast enough though.
Core 2 Duo 2.13ghz
4GB DDR2
Win7 32 Bit
geposted Tue 02 Mar 10 @ 11:15 pm
Performance tab:
Auto
Performance tab:
Auto
theres a button for turning the platters off "Scratch off" :)
geposted Wed 03 Mar 10 @ 5:12 pm
Wow. I never really read it. I always glanced at it and thought it said "monitor off". Here it says "motor off".
I finally got the 32bit installation done and working. I must say it does work a lot better than the 64bit.
I can vaguely hear a little scratchiness in the sound when adjusting the pitch (keylock on or off). That is thru my headphones. I'm curious how loud it would be on a loud system. But the sound does not break up when loading tracks. The CPU peaks but no distortion in sound.
I will be obvserving it over the next few days to see what happens. I have the ASIO config at 512 samples. VDJ config is auto with both unchecked.
geposted Thu 04 Mar 10 @ 12:17 am
thats awesome man congrats
im still strugglin...cant get it to work on xp...and i noticed new drivers for 32 bit for vista and 7 but those systems i got are 64 n i dont have access to 32...and well i dunno how or when ill get this workin
geposted Thu 04 Mar 10 @ 4:31 pm
