Hey everyone, I just wanted to make a quick post about a recent bug I've discovered. I'm using time-coded vinyl, 2 TT's running through my Hercules RMX. I've toyed around with every setting possible and it doesn't seem to stop this. Here is the issue. When a TT deck plays through to the end of the record and I don't reset the needle to the beginning in time the sound switches over to the hercules deck respectively. A great feature in my opinion, but once this happens the BPM gets wrecked. It becomes impossible to match my two TT's again after this happens, even after the audio is back on both turntables. The only solution is to reset the program. Usually I dont let this happen, but in a 4 hr set i tend to slip up every now and again. I hate to be another person posting about bugs and what not, but I figured it might be helpful to point out. THanks!
-L
-L
geposted Tue 02 Mar 10 @ 4:13 am
Thank you for posting it! I've recently bought one hercules rmx myself, and use it as a controler, but I am noticing that in every song after a while, begins to bumps the music, like when you are using a TT and someone touchesit and it skips, but without loosing the beat..... weird.
geposted Tue 02 Mar 10 @ 6:26 am
