anyone have a working shortcut for using keyboard only to clone_deck? that feature does not work correctly after 6.3 update.
geposted Tue 02 Mar 10 @ 6:26 pm
Works fine in 6.0.5 ... clone_deck by itself uses the PFL deck location to determine which deck gets cloned.
If you want to make separate shortcuts to specifically clone a deck then use ->
deck 1 clone_deck <- always clone deck 1
deck 2 clone_deck <- always clone deck 2
geposted Tue 02 Mar 10 @ 8:09 pm
Thanks for the reply. Maybe its just my lappy. I tried every kind of shortcut i could think of and getting the decks to clone won't work. I always use one key ( C Tfor both decks. If the pfl is on deck A when i press C deck B clones deck A and likewise if the pfl is on deck B. Now either decks won't play the clone song. It loads the clone but just wont play. Anybody has a single key shortcut for deck cloning please let me know...Thanks
geposted Wed 03 Mar 10 @ 11:58 am
