Topic: buying a hercules rmx
good morning to the vdj community !
i am thinking of buying a hercules rmx.
i allready am a owner of vdj pro, and it works perfect with my total control, but i am looking for a all in one solution.
my question is : will the rmx work out of the box with my allready purchased & installed & perfectly working vdj pro 6.05 ?
do i just need to install the rmx drivers and nothing else ?
thank you very much for your time & and a great piece of audio software ( which i never regreted buying 2 years ago !!!)
geposted Wed 03 Mar 10 @ 2:42 am
yes you can easily install the hercules driver from the internet and plug in your rmx and go with it.
The Mapping is in Virtual DJ integ. also some coustom Mappers are available in the Tools Sektion.
https://virtualdj.com/addons/tools.html
thank you very much for the fast answer !
I had to uninstall my Audio Kontrol 1 drivers before the RMX drivers would go in and work. Other than that it was simple, you must reboot before the ASIO drivers are recognised too.
I Love My RMX You Will just need to install the rmx drivers and And Update And Mapper ( 6.5+ ) nothing else.
https://virtualdj.com/forums/124701/General_Discussion/Want_to_buy_a_Hercules_RMX__and_have_a_few_questions_.html
