Posted this in the other thread but i don't think people are seeing it...only 3 people have read that thread in last 2 days.....Don't know if this is a fix for your particular problem or not.....This was passed on to me and seem to "fix" the problem....i'm running win 7 32 bit, with 2.3 ...and 4 gig ram with 1 dedicated to video...In vdj config...options...i changed load from max load to 15min.....it seems that memory builds up and after a long period it cause video to freeze...load real slow or not load waveform all the way...this seems to have cured my problem...it seems in watching it that my cpu never runs higher than 40%....normally is in the 16-22% range...builds up to 40% over 10 -15 min time period but then "Dumps" that xtra cpu usage and goes back down to 16-22%...When video loads for 6-8 secs cpu jumps normally to 65%...I've ran videos for 4 hrs straight at home in automix and no problems....then i let it run overnite while i slept and after 8 - 10 hours ...videos still playing cpu usage still at the 16-22% range ...builds up to 40% and then drops back again after about 15 min...I'm running video + random clipbank + showlogo...I have audio loaded on other deck and crossfader in middle so that video and clipbank are sharing output screen plus transition......I'm playing all mpeg-4...hope this helps you!...I haven't gig'd with it since the change...thats coming on Friday.
geposted Wed 03 Mar 10 @ 7:49 am
What version of VDJ are you using?
geposted Wed 03 Mar 10 @ 11:38 am
6.05
geposted Wed 03 Mar 10 @ 3:41 pm
Mac or Windows?
geposted Wed 03 Mar 10 @ 3:45 pm
Win 7 32 bit
geposted Wed 03 Mar 10 @ 4:05 pm
Nutributnet,
Thanks for the effort. I tried changing load from "auto" to 15min. Errrpp.... It didn't work for me.
My CPU stays arond 20-30 %
One thing I noticed. When I slow down the video real slow, and it goes into lock issue, the video circle-loops for a while till it freezes.
Hopefully this helps.
HP Laptop DV-9500 CTO
T-7500 2.2 gHZ
XP Pro 32
2Gig Memory
Nvidia GeForce 860M GS
Regards,
JimJam
geposted Wed 03 Mar 10 @ 6:58 pm
