Anyone know of a good tool to adjust the audio on vob files? Like mp3gain for vob.
Thanks in advance,
T
Thanks in advance,
T
geposted Thu 04 Mar 10 @ 1:49 pm
Thanks in advance,
T
Thanks in advance,
T
Sony Vegas might do what you want. Record your audio. Then import the video into a Vegas timeline and mute the audio. Add your modified audio track and align it with the video. Save the project.
geposted Thu 04 Mar 10 @ 6:53 pm
I was afraid this would be the only way, but it makes sense. Thanks, Jimmy.
geposted Fri 05 Mar 10 @ 8:38 am
There are several programs that will allow you to adjust the audio channel for most video file types.
Google: Total Video Converter 3.60 OR Xilisoft Video Converter both these will allow you to adjust the audio track volume.
I personally use Vegas which will allow you to increase the volume on the existing track which is the simplest way OR you can import the audio track directly from a CD as a .wav or you can use an mp3 file and replace the original track. Normally if I have issues with an audio track I replace it. (I've noticed the low volume issue when dealing with commercial DVD's designed to play on DVD players rather than VJ specific DVDS like PromoOnly)
Renee :^)
Renee :^)
geposted Fri 05 Mar 10 @ 10:34 am
I use Vegas as well for this.
geposted Fri 05 Mar 10 @ 12:55 pm
what version of Vegas do you kids run?
geposted Fri 05 Mar 10 @ 2:22 pm
recommend a resolvent:
with " ddvideo video to mp4gain "to convert vob video to mp4 format,meanwhile you set target output volume (from 75db to 105db) by VolumeGain box.the software is very easy to use.you can google the software to try it.hope it can help you.
geposted Wed 29 Dec 10 @ 2:44 am
