Hi there - first of all my Crashguard Report:
Crash ID=0048c002 (date=1002250000, version=6.0.3, build=603, thread=Main, dump=0100e847, excode=c0000005 (1,2c))
Crash ID=004d86ea (date=1003042032, version=6.0.3, build=603, thread=Scan, dump=8a068807, excode=c0000005 (0,2a08135))
I run Virtual Vinyl with the VV interface and vinyl timecodes. The Skin is "Scratch v6.0:Basic Black (1280x800)_v6".
What I find interesting about this is, that it only seems to happen in XP.
I run Vista 32 Bit Home Pemium and XP Pro SP3 on different partitions of the same machine.
Both partitions are hidden from each other when running the other OS and I put the "My Documents" folder (replaced the location in registry for both OSs) on a third partition, so I can share the playlists and other stuff with both OSs.
I installed XP because under Vista the CPU (1.6 GHz Core 2 Duo) seemed to exceed its possibilities (had tiny glitches when loading tracks that did not occur under XP).
Anyway, under Vista I NEVER EVER had the smiley screen and with my XP installation I had crashes on 2 Gigs in a row.
Good thing is, at least the track keeps on playing to the end, but on the other hand I wonder why it's forced to shut down, then.
Hope you can make anything of the information - for any help, of course, I would be pleased to answer further questions.
geposted Fri 05 Mar 10 @ 5:27 am
