Just did my last show with my numark icdx' last night.
These players are great along side vdj its the
Perfect combo. Been a good 2 years.
My NS7 should be arriving today.hopefully
Ill have the same sucess with that.
geposted Fri 05 Mar 10 @ 8:19 am
I am glad That they work for you ,for what you paid for etc, But Im sad and frustrated they where useless to me I never found the cure for the "jog unespected behaivor" I still have them storaged I like new I wish I find a buyer!!
geposted Mon 15 Mar 10 @ 9:46 pm
i had that issue too. I narrowed it down to power to be honest. I felt i would get power spikes when my hand would touch. I know it sounds weird, but thats what beleived it was.
I started to power the DJIO via power for the last 6 months, and really splitting the power when doing mobile gigs. Issue went away.
Try it out.
Try it out.
geposted Mon 15 Mar 10 @ 10:15 pm
Ditto. I experienced the same problems. The glitch was happening a minimum of once every gig (usually 3 or 4 times) where the next video clip would suddenly half load on the screen if the platter was moved and a pop-up box asking me if im sure I want to load the song and any loop or cue was reset also. I managed a temporary fix for a few months in recent versions when you could use the scratch slider option all the way to the left, and not scratch at all, but unfortunately it just popped up again in my last gig.
Wish I had gone with the CDJ-400's instead.
geposted Mon 15 Mar 10 @ 10:16 pm
I know your posts are from long ago... but just curious what firmware version were either of you using?
geposted Mon 26 Apr 10 @ 4:56 pm
I was using 0.50
geposted Mon 26 Apr 10 @ 9:57 pm
