Ok, so ive accepted the fact that the new 6.0s are not ever going to be as stable as 5.2.1, not for my machine that is... What i find hard to believe is that i am the only person who has this problem... I would love a Midi Map for my Denon S-3700... Is this just not gonna happen???
Its not my computer's fault that the 6.0s dont work, i have plenty of Ram, the newest OS system, and 5.2.1 runs beautifully... 6.0 runs ok, its the video engine that turns everything to crap... Why this couldnt have been left alone is beyond me...
geposted Fri 05 Mar 10 @ 7:23 pm
Hello you could use the mapper for the 3700 that this here is for version 6.0.5: http://fr.virtualdj.com/addons/8706/Denon_DN-S_3700_Mapper.html
geposted Sat 06 Mar 10 @ 12:44 am
This version works in 5.2.1 ???
geposted Sat 06 Mar 10 @ 6:30 pm
No, as he wrote you need to have the latest Version (actual 6.0.5) of VDJ. There is a new controller engine since 6.0 which allows easy implementation of most MIDI controllers.
Greets, Heiko
Greets, Heiko
geposted Sun 07 Mar 10 @ 4:17 am
Thats the reason for my posting...
My Macbook Pro is only 2 years old, i have 2 gig's of Ram, a 7200 Rpm internal drive etc etc... There is no reason that 6.0.5 video output should not work on my machine, but it doesn't... And nobody seems to be doing much about it...
When 6.0 came out we were told that it was supposed to use less system resources then 5.2.1... If this were true, then one would think that the video engine for 6.0.5 would work as well as the earlier version...
It doesn't, and from what i read in the forums, people are still having a lot of the same issues... So if a 6.0 version can not be made to work on everyones computer currently running 5.2.1 without any problem, then i dont see why 5.2.1 shouldn't continue to be supported...
geposted Sun 07 Mar 10 @ 10:51 am
Chris ... did you get my PM?
Well try 6.0.7 Mac :)
geposted Sun 07 Mar 10 @ 10:56 am
No, but I'll look when I get home. Using Iphone right now to respond.
geposted Sun 07 Mar 10 @ 1:01 pm
