I have omni control now I have my macbook pro and VDJ 6 but my keys on the mapper are not correct and some have no action ... and i already try to map it my self but no luck please help !! Also I got a mapper but how do you install it in VDJ 6 i already put it on the mapper folder but nothing happens ?
geposted Sat 06 Mar 10 @ 12:11 pm
Hey
I have a post just a few down from yours and I think that there is one other on here too
The midi mapper is in the software and I managed to map out most of the controls on there. the only ones that won't map are the effects and sampler ones.
I set up the effects on one side (left) then move over and set the effects up on the other side and then it cancels out the left side again... have tried and tried but no luck so far.
if anyone can help it would be great
Thanks and good luck
geposted Sun 07 Mar 10 @ 12:40 pm
