Forum: Greek Forum
Topic: Virtualdj 6.0.7 - Page: 1
apopsisdjPRO InfinitySenior staffMember since 2003
Kyriws bug fixes, pali proteraiotita stin statherotita.
# video engine optimization
# many new controllers added
# automatically select best skin fitting your screen resolution
# don't display netsearch results that are blocked in your country
# enhanced tracking for motorized wheels (S3700, HS5500, NS7, V7)
# enhanced latency for highdef wheels (CDJ400, CDJ900, CD2000)
# show history playlists from recent to older
# bpmdiff now uses the deck's pitch modifications
# pressing play after cue keeps playing (pioneer's way)
# freeframe plugins get slider names and default value, and can display more than 3 sliders
# fixed 5.1 sound in video files (AC3)
# fixed dump action
# fixed clipbank previews
# fixed virtualfolder_add
# fixed last seen in minutes when was between 60 to 99 minutes
# fixed some memory leaks
# fixed loop_select LEDs
# new registry hack VideoMemMaxUse
# added action "get text" without number for single-line displays
# in MIDI definitions, <fulljog> can use pitch="true"
# new actions: speedwheel, speedwheel_touch. New item for HID definitions: <jogspeed>
# fixed multiple LEDs on same MIDI note with different values
# fixed ccmsb2 in MIDI definitions (fixes DAC2 bpm)
# new item for MIDI definitions: <text sysex="">
Kai kapoies mikres allages to timecode pitch tracking
http://www.virtualdj.com/wiki/VirtualDJv6.0.7.html
geposted Sun 07 Mar 10 @ 7:20 am
aledjoPRO InfinityMember since 2005
me 1kb/s katebazo
xaxaxxaxaa
auto me to rename de to kanane e?
eimai periergos na dokimaso auto pou leei me to play kai to cue an douleuei opos sta pioneer
geposted Sun 07 Mar 10 @ 7:31 am
oxi kai to zitisa kai ego.
geposted Sun 07 Mar 10 @ 8:18 am
##new actions: speedwheel, speedwheel_touch. New item for HID definitions: <jogspeed>
osoi exetai controllers cdj-400/900/2000, kai exete ftiaksei diko sas mapper...
Epidi einai diaforetiki i entoli gia to jog/scratch wheel se aytin tin ekdosi, kalo einai na kanete reset ston ergostasiako mapper, i na kenete edit ton mapper me basi tin antistoixi entoli tou default mapper.
copy apo to antistoixo forum - alla kalytera reset na eiste sigouroi.
reset the mapper to factory default if you changed the mapper. Or at least manually change JOG_WHEEL to "speedwheel" instead of "touchwheel")
geposted Sun 07 Mar 10 @ 8:24 am
"pressing play after cue keeps playing (pioneer's way)"
to prospathisa alla de ginetai.
ti kano lathos?
geposted Sun 07 Mar 10 @ 8:35 am
telika douleuei auto me to cue kai to play.
stin rmx pou dokimasa simera sti douleia, to kanei akribos opos ta cdplayers.
oxi oti to xrisimopoio katholou auto alla leme tora.
pantos simera gia 7 ores to vdj 6.0.7 doulepse kanonika.
geposted Sun 07 Mar 10 @ 5:52 pm
Mporw na omologisw..oti einai i kalyteri video version pou eixame pote.. Mpravo.
geposted Sun 07 Mar 10 @ 7:10 pm
Επειδη δεν το εχω δοκιμασει ακομη τι διαφορες παρατηρησατε;
geposted Sun 07 Mar 10 @ 9:29 pm
To vasikotero olwn einai oti exei eksalifthei sxedon to kollimataki tou ixou kai tis eikonas otan fortwneis video sto allo deck. Episis paratirisa oti veltiothike poly o xronos fortosis toso tou video alla kyriws twn arxeiwn ixou pou fortwneis meta apo video. Dld an eixate paratirisei, enw eixes fortwmena video, an prospathouses na fortwseis arxeia ixou (safws elafrytera) epairne poly xrono mexri na ta fortwsei. Twra auto exei diorthwthei aisthita kai einai tha elega akrws apodekto.
geposted Mon 08 Mar 10 @ 11:17 am
apopsis
na sou pw gnwrizeis giati sta mac den mpwrw na kanw broadcast apo line-in?
geposted Wed 10 Mar 10 @ 11:49 am
kalispera tha itherla na matho an doulevei kai me windows 7 64bit to virtual eyxaristo poly
geposted Fri 12 Mar 10 @ 11:07 am
Douleuei, arkei na exeis tous drivers gia tin karta ixou kai ta perelkomena (controllers klp)
geposted Fri 12 Mar 10 @ 5:13 pm
xereto oloi tin parea tou forum.exw tin konsola mk2 hercules...tha ithela na rwtiso kati...skeftomai na agoraso tin pro ekdosi tou virual dj kai thelo na matho an tha douleyei me tin mk2 i prepei na parw kapoia allh konsola opos tin rmx?
geposted Sun 14 Mar 10 @ 7:01 am
douleuei me tin pro ekdosi kanonika kai full
geposted Sun 14 Mar 10 @ 8:13 am
se eyxaristw alex
geposted Sun 14 Mar 10 @ 11:48 am
Πράγματι, με Windows 7 είναι απίστευτα γρήγορο στον τρόπο που φορτώνει τα βίντεο.
Επίσης, επιβεβαιώνω κι εγώ, πως πράγματι παίζει τα βίντεο, πολύ καλύτερα από τις προηγούμενες version.
Δεν το έχω δοκιμάσει στο Macintosh της δουλειάς.
Επίσης, μόλις φόρτωσα την βέρσιον 6.0.7 είχε κρατήσει και θυμόταν στη registry την ρύθμιση που είχα κάνει παλαιότερα με τον APOPSIS για να έχω χαμηλότερο ήχο από 0db.
Νομίζω πως το πρόγραμμα από την version 6.0.6 και ειδικά στην 6.0.7 βελτιώθηκε αισθητά.
geposted Tue 23 Mar 10 @ 5:51 am
Gia ayto ithela kairo na se rotiso, ti egine eides diafora ?
Otan sou edosa to patch, to ekana sygxronos kai sta dika mou just in case, alla epeidi den exo kapoia sygkekrimena arxeia na paramorfonoun, den mporo na po me sigouria.
A, kai kati allo pou prepei na prosekseis kai mporei na sou dimourgouse clipping.
H rythmisi "auto gain" an einai auto+remember einai epikyndyni. An exeis peiraksei to gain (pros ta pano) apo kapoio tragoudi to thimate tin epomeni fora pou to fortoneis. Balto aplos sto "auto". To eixa ayto to problima me enan filo pou douleye me hercules Rmx kai synithize na peirazei ta gain, opote kapoia tragoudia tou paizane paramorfomena.
geposted Tue 23 Mar 10 @ 6:12 am
g.asenHome userMember since 2010
Kalispera se olous!!
apo analogikos eipa kai ego na gino en meri psifiakos!!!!
exo to virtual dj 5.0 6 kai molis peira kai ti maya 44 USB ESI
thelo voithiai me ti sindesmologia tis kartas-pc-decs (tis rythimiseis tha tis do apo kana video you youtube)
kai an ginete me kapio tropo na allazo ta time codes me audio cd se pragmatiko xrono!!!
efxaristo!!!! ;-)
geposted Tue 23 Mar 10 @ 8:22 am
Την ίδια MAYA την έχω κι εγώ.
Επίσης έχω MAYA (αλλά για PCI) και την έχω εγκαταστήσει σε 5 μηχανήματα από μαγαζιά, όπου σε όλους έπαιξε τέλεια.
geposted Tue 23 Mar 10 @ 12:08 pm
Φίλε Apopsis, στο μαγαζϊ που δουλεύω, αφού εγκατέστησα Windows 7, πρόσεξα ότι σε μερικά τραγούδια υπήρχε η γνωστή παραμόρφωση.
Τελικά, είχα ξεχάσει να ρίξω το αρχείο στη registry.
Και για να απλοποιήσουμε τα πράγματα, το μόνο που χρειάζεται να κάνει κάποιος συνάδελφος (αν φοβάται να κάνει διπλό κλικ στο αρχείο .reg) είναι να μπει στη registry (run=> regedit) και εκεί να πάει στο εξής σημείο...
HKEY_CURRENT_USER\Software\VirtualDJ
Εκεί, στην ρύθμιση"ZeroDB"
Θα πρέπει να αλλάξει αυτό που έχει με 17a2.
Αυτό ήταν όλο!
geposted Tue 23 Mar 10 @ 12:12 pm
50%
