I've just bought a set of Pioneer CDJ-400's. However i can only make the effect buttons (Jet,wah,roll and so on) work as hot cues. Pressing hold only allows me to delete the hot cues. Looking at the mapping it seems i can access the effects too, i just dont know what button to press?
geposted Sun 07 Mar 10 @ 10:58 am
These are all natively mapped as part of the controller support of those units. Download the latest trial version and test them out.
geposted Sun 07 Mar 10 @ 11:01 am
I have the latest version, but i can only use these buttons to access hot cues, not effects ?
geposted Sun 07 Mar 10 @ 11:02 am
You press the HOLD button to access the button menu ..
geposted Sun 07 Mar 10 @ 11:16 am
Pressing the hold button only allows me to delete hot cues. What do i have to press, and i what order?
geposted Sun 07 Mar 10 @ 12:48 pm
Lets go to the hardware tech supp -pioneer forum You ll find every last update help there
geposted Sun 07 Mar 10 @ 4:19 pm
Pioneer forum will not help in this case as he is not trying to access the onboard effects.
@Janzeh - please check the mapping for the TEXT entry of the CDJ-400 mapper - what value is listed for the VDJscript. If it is not 'get text' then change it to that and see if the HOLD button gives you a menu on the display.
geposted Sun 07 Mar 10 @ 6:23 pm
The entry for TEXT is "var "$show_artist" ? get artist-title : get title-artist".
geposted Mon 08 Mar 10 @ 8:10 am
Change it to:
get text
(Otherwise the menu and other information will not be shown.)
You can also manually map the buttons if you wish, e.g:
effect 'Flanger' active
get text
geposted Mon 08 Mar 10 @ 12:19 pm
