Hey there,
i would use my MAC Version .. but i wait form 6.0.2 to 6.0.7 and the Waveform is still hanging and do not run very well.
When i started my XP on Bootcamp, there is no hanging on the Waveform.
On my Windows 7 64 Bit PC is the same bug.
There are so many Mac-Users with VDJ and noone got this issue?
Regards Max
Regards Max
geposted Mon 08 Mar 10 @ 10:56 am
I'm a Mac user and I don't have this issue.
geposted Mon 08 Mar 10 @ 12:11 pm
no problems with the waveform here either.
geposted Mon 08 Mar 10 @ 12:50 pm
And wich MAC?
I got the Macbook Late 2009 (OCT2009) 4 GB RAM.
Hm ... what can i do ? ... I dont know any more way ... =(
geposted Mon 08 Mar 10 @ 3:32 pm
No problem here as well.
When you said hanging, is it for a second and jerky?
geposted Mon 08 Mar 10 @ 10:52 pm
no its just all the time.
There is one Video :
Look at the Waveform, this is my Problem. The Time and other things run with no hanging but the Waveform is hanging.
My Eyes get crunk with this .. =(
Max
Max
geposted Tue 09 Mar 10 @ 2:46 pm
After looking at the video I noticed your CPU was running unusually high. It seemed to be hovering around 80-90% all the time. When I run VDJ it hovers around 15%. I think it may be a hardware issue.
geposted Tue 09 Mar 10 @ 6:37 pm
can you post a video with nothing playing?
try setting you performace all the way to the left, and put your latency on auto.
geposted Tue 09 Mar 10 @ 10:20 pm
I was messing around with my timecodes and the pitch sensitivity setting in the 'debug' sub-window of the timecode set up window, and I noticed that if you have the pitch sensitivity set too high it causes the waveform to be quite jerky. Try playing with that setting and see if it works.
geposted Wed 10 Mar 10 @ 9:18 am
The CPU is to high cuz its recording this Video.
The normal CPU usage is 20 %.
I found a Guy in the German Forum with the same Bug.
There is a better Video:
U see the Waveform is not normal... this is the Bug i mean.
I set Timecode off cuz i use the Vestax Vci 100 .. i try a lot of things .. but i dont know.
My Macbook got now 4 GB Ram ... and nothing is better.
@DJ Cyder
Hm a Video with the Decks stopped?
Or what u mean?
So on .. Max
@DJ Cyder
Or what u mean?
So on .. Max
geposted Wed 10 Mar 10 @ 11:56 am
My waveform looks exactly the same but I never thought of it as being "jerky". Mind you I usually don't zoom in on the waveform that much. I don't know what to tell you, it's a wee bit jerky but is it really that big of a deal for you? Serato's waveform is smoother but not by much.
geposted Wed 10 Mar 10 @ 3:03 pm
My Eyes are the Problem ... i look to it and i get crank :) Sorry thats it is ...
My Waveform get hanging any more, but my Problem is :
On MAC the Wavform is hanging
WIN 7 the Waveform is hanging
On Bootcamp XP the Waveform is running good.
All OS at the same Notebook... that is no normal...
Id like to work with MAC and not XP with Bootcamp.
Max
Max
geposted Wed 10 Mar 10 @ 4:09 pm
Maxstell1 wrote :
Hey there,
Regards Max
Regards Max
i have exactly the same problem - on MAC not OK, on XP perfect (actualy i did make it hang on xp too when i changed the audio setting form 2 channel mixer and 2 asio sound cards to 1 single output - but now back to 2 channel mixer and its fine on xp)\
geposted Thu 11 Mar 10 @ 12:37 am
Hm .. there are a lots of people with this Problem.
Atomix, is there any way to slove this Waveproblem?
Max
Max
geposted Thu 11 Mar 10 @ 6:33 am
Hi, what is your performance settings?
Anyway, is this with the default decoder or using the quicktime audio for the mp3?
Can you test using the latter as your decoder for this and see if there is any change?
geposted Thu 11 Mar 10 @ 6:37 am
-My Performence is at the "fastest".
-My Decoder is Quicktime oder Mp3, doesnt matter.
I can change any Decoder... nothing Change.
Do u mean its the Decoder which produce this hanging?
geposted Thu 11 Mar 10 @ 9:10 am
tried every settings a could imagine. didn't sold it.
geposted Fri 12 Mar 10 @ 12:15 am
Sorry, i send u a mp3 , but all my songs produce this .. :/
I have a new Info:
I testet SSL and Traktor ... THE SAME ERROR =(.
->I think it is the Driver of the Videocard...
All newer Driver produce this .. with Bootcamp XP are no Errors... even with Traktor and SSL.
I think its not VDJ`s Error ..
I have a new Info:
geposted Tue 16 Mar 10 @ 11:47 am
Hi Guys,
I'm the man of the second video. In my opinion, our problem is a teamwork of Vsync and Asiodriver. I use 2 systems with completely different sound and video cards. On both Windows 7 and Virtual DJ in the latest version on it.
Compatibility mode also brought no success. Argh....what the fu**.
Please continue helping us. This problem is killing us!!!!!
Big THX to all.
Big THX to all.
geposted Thu 18 Mar 10 @ 8:45 am
I have exactly the same problem with my Macbook Pro. The waveform display is not smooth.. Is like running on 10-15 fps. On my Pentium 4 (3Gig) PC with WinXP is running like a fluid...
I have this problem for the versions earlier than 6.0.
If someone hasn't look the smoothness of waveform running on XP it will belive that the motion on MAC is ok.
geposted Sun 11 Apr 10 @ 9:11 am
