Hi, problem over here. I've downloaded the latest software, i'm running windows 7. Formerly on Vista, everything went smooth. Now when I want to start VDJ, there's a popup saying 'we will check the net for updates', followed by a popup 'The controller could not be detected, please plug your controller and start VDJ again', which I have done like 120x, but no results.
Who can help me plz?
Thanks!
Bert
Thanks!
Bert
geposted Wed 10 Mar 10 @ 3:48 am
Call Hercules tech support. Ask for Adrian. There is a fix and it takes about an hour. Windows sucks!
geposted Wed 10 Mar 10 @ 7:43 am
check this out it may help...
https://virtualdj.com/forums/125375/PC_Version_Technical_Support/RMX_Install_Issue______HELLLLP.html
also go to the previous page to get the run down on the install.
geposted Wed 10 Mar 10 @ 9:46 am
Problem solved!
Thx!!
Thx!!
geposted Wed 10 Mar 10 @ 5:03 pm
