Topic: Numark ndx800 - Page: 1
Hi all,
I already have vdj pro and i'm considering to buy two numark ndx800 with a mixer.
I saw a few posts concerning the numark ndx800 and the fact that virtual dj doesn't recognize the 2 decks.....it is ok now with the new version of virtual dj ??
i just got back from the store and i tried the ndx800 and it's amazing.....
before bying these controller i would like to have some feedback about owner of ndx800....... how do you connect these thing to work with vdj and is it working properly ???,..
many thanks...
Marty
geposted Wed 10 Mar 10 @ 12:47 pm
I HAVE TWO NDX800, THEY WORK GREAT. THE BAD THING IS THEY CAN'T NOT BE USED A CONTROLLER TOGETHER BECAUSE THE MIDI OUTPUT FROM BOTH DECKS ARE THE SAME AND CAN NOT BE CHANGED. I HAVE CONTACTED NUMARK AND THE SAID IN THE FUTURE THERE MAY BAY A FIRMWARE UPDATE TO CORRECT THIS COCNERN. I USE THEM AS CD DECKS BUT UNHAPPY THEY CAN ONLY BE USED ONE AT A TIME AS CONTROLLERS.
i have the same problem as instasound. works great as cd players. but i mainly bought them to control Virtual Vinyl but numark is slacking in controller support updates. i think having the updated Virtual Dj Pro has the controller listed maybe? But it frustrates me to purchase basically the exact same thing!!!!!!
Providing they each have their own separate USB interface, then this won't be a problem once a proper controller definition is made.
Development of a definition and mapper for these units is underway. Once completed and validated then they will be made available for download and/or embedded in the next version (which ever is most practical at completion).
thanks for the heads up teamer!!! Now is this update only for Virtual Dj Pro or Virtual Vinyl also???
hi!
do the ndx 800's have loop cut? like 1/4 1/8 etc...
hi!
Yes they do.
Hi all,
many thanks...
Marty
I have two NDX800s and LOVE them! VDJ does not recognize them but I used the mapper option and they work great. What I also did is I made the search switch on the NDX's as a selector to active the deck I want to use - select to the left, activates the left deck, select to the right, activates the right deck. I also mapped different buttons to trigger different options like cue points on the opposit deck to that I can do things with both decks at the same time :)
THANKS FOR THE MAPPER!!!!!!!!!!GREAT WORK!!!!LOVE THE NDX800S!!!!!!!!!!!!!
GOT THE MAPPER INSTALLED AND WORKING, GREAT JOB I MAY SAY! STILL HAVE NO TRACK INFO AND THE BPM IS NOT CORRECT. ANY HELP???????????
Hi all,
with the new mapper the two decks are now recognized with VDJ ???
Is it true..?
thanks
One more question
Numark NDX800 is it working well with windows 7 64 bits ???
I'm running 2 NDX 800'S with a Hercules RMX, with Windows 7 64bit. This is what I did; I plugged them into my USB's and waited for them to be ready to use. Then I went to Numark.com and downloaded the newest firmware. THE FIRMWARE MUST BE LOADED ONTO A USB FLASH DRIVE since it is a .bin file. The instructions and update reasons are included in the download. Then I opened VDJ and opened settings then mappers. Click on the box to search for new devices and bingo they work fine. The only complaint I have is scrathing isn't as crisp as it was using timecodes but that can probably be resolved by tinkering with my latency. I'm going to play with it when I get home and I'll update you guys.
M.E.T.R.I.M.S. ENTERTAINMENT
with the controller now you have to modify the sensitivity in the option to get the right feel.
Got a message saying
"Sorry, you don't have the necessary accreditations to view this page." What do I need?
You don't need anything ... the definition and mapper are no longer available for download, because they are part of that latest version 6.0.8.
Thanks
i still need the mapper because i use virtual vinyl. can anybody help????
The mapper should be built into the latest download of VV
69%
