i have a problem with my d j console ,when i start it up it will not read the software on my computer so i try upgrading it and it still did not work what should i do
Thank you........
Thank you........
geposted Wed 10 Mar 10 @ 2:20 pm
ok mate first things first.
hint 1...always use the same usb port for your rmx(not hub laptop only)
download newest drivers form hercules website and continue to install drivers with rmx out of laptop.
only plug usb in when prompted to do so.step by step
geposted Wed 10 Mar 10 @ 2:50 pm
I use the same wire since i bough it a did everything you said and it still dose not work and I'm using it for a desk top computer...
geposted Wed 10 Mar 10 @ 3:27 pm
not usb lead mate the same usb port on your computer.
ok go to control panel and remove hercules drivers from your computer.
and follow previous steps.make sure the downloaded drivers are right for your o/s type,
save file to computer then open and run file(new drivers) and only plug rmx in when told.
shut down all other apps before installing.
and we all had problems and i used to get very annoyed and blame everything.take your time breath and follow steps clearly
JUST READ ORIGINAL POST MATE.WHEN YOU START YOUR COMPUTER IS YOUR RMX RECOGNISED.IF SO WHICH VDJ ARE YOU USING.IF YES GO TO MAPPERS AND SELECT YOUR RMX.ALSO TRY DOWNLOAD RMX MAPPER FROM DOWNLOAD SECTION SO YOU CAN MAP YOUR BUTTONS FOR WHAT YOU WANT TO DO
geposted Wed 10 Mar 10 @ 3:41 pm
ok... Ill try that thanks.....
geposted Wed 10 Mar 10 @ 3:49 pm
just make sure your rmx is being seen by computer.plug in rmx then turn on computer.in tray on bottom right rmx shown click on it and you will see you settings.then go open vdj.go to mappers...click dropdown box and choose show connected hardware..
geposted Wed 10 Mar 10 @ 3:53 pm
Thank you very much its working well now.....thanks again
geposted Wed 10 Mar 10 @ 4:29 pm
glad i could help.first time for everything lol.you will love your rmx mate even though ive changed i still love it.mapp it the way you want and your job is half done.enjoy
geposted Thu 11 Mar 10 @ 4:58 pm
Good Advise Staffy ! Luv your RMX and it will LUV you back! .....lol..
geposted Fri 12 Mar 10 @ 1:15 am
