Hi
i have a little problem...
i make a music a Numark omni controller, and so far i use a 6.0.2 version of virtual vinyl
i updated a 6.0.3 and the controller so many button swap... :(
the select button - filter on/off but only the first side
etc...
my friend have virtual dj, 6.0.6 version, we try this...
but he also found the bug...
please enybody help me!
THX
I like VDJ program, i believe this is the best Video Dj tool!!!
etc...
THX
geposted Wed 10 Mar 10 @ 10:24 pm
I am having the same problem
loop in does nothing, loop out is a hot cue
the effects are lacking simplicity and why does the right side effects fast foward the pfl song
I dont know, I am defly confused...let me know what you find out
Its already annoying me and I have had it for 2 hrs
Numark says to set it up your way in config, but you would think there was a simple mapper out there
geposted Thu 17 Jun 10 @ 6:08 pm
Please use V6.0.7 if you have not updated.
geposted Wed 28 Jul 10 @ 8:42 am
the problem is the same too in 6.0.7 :(
geposted Wed 28 Jul 10 @ 8:44 am
