Topic: pitch speeding up
im using a da scratch with a numark total control and korg nanopad and nanokontrol and since i installed the latest version of vdj i have a problem with tracks that are playing,as the song goes on its speeds up fast without changing the numerical pitch indicator,then will slow down to normal speed and just keep speeding up and then falling back to normal speed,and there is no way i can stops this happening once it starts,i have to shutdown vdj and open it again and the same thing happens less then 30 secs into a song,does anyone have this issue or can anyone advise on how to solve this issue itd be appreciated
geposted Thu 11 Mar 10 @ 4:40 pm
Are you still using the older DaScratch definition and mapper .. or did you reset the device to channel 1 and are now using the new native definition and mapper?
Not saying it is the DaScratch that is causing it - but out of the 3 controllers, it is the only one that was updated in this release.
i deleted everyhting and reinstalled 6.07 and i deleted the old mappers
i tried running with just 2 da scratchs and the total control but had the same issue so im trying just one dascratch (reset to midi channel 1) and the total control and when i try to cut and scratch after a few seconds of sounding alright the channel i have selected with dacratch speeds up still im not sure whats up but any help is always appreciated
getting this error now, was there ever a solution?
