Hi, I have Gateway FX 4gbram DD3, 1Gb Video, windows 7 Home premium 64 bits
VIRTUAL DJ works great until i connec my hercules rmx console...
when i connected it the videos starts to freeze slowly, and the audio cut a lot
The USB ports are fine, High Speed
The Hercules Sound card is cool too
I dont know if i have no configure sometthing, erase somtehing, i need to get this thing work...
If somebody knows what do do about this problem, please Ill appreciat it.
geposted Sat 13 Mar 10 @ 3:06 am
ts.hercules.com
Navigate to the proper drivers in support there and follow the instructions exactly when prompted.
When installing, save to your desktop, then right click and select run as administrator and copy the vdj folder at my documents to other user accounts to the same location if they are in use.
Make sure you use the same usb port each time you plug in, the dj icon at the lower task bar should not have a red x through it when in use.
Do not plug this device into a hub, run it directly to the pc.
geposted Sat 13 Mar 10 @ 6:43 am
