ok, so i've not got a new Laptop (dell- Latitude D630, dual-core and using XP Pro...) and its FAB.
However, when using my RMX with it, every now and again the sound freezes, only for a split second but its noticable. This happens on one "deck" if its only one playing but happens simultaniously if both are playing together.
I'm using the ASIO sound card installed on the RMX and nothing is tripping up the computer (in the background) as i only have VDJ, The RMX and AGV Free Anti-virus running on this Laptop.
The System usage meter tells me that the CPU is only running at about 14%max so shouldn't be a problem there either!!!
Any ideas? Any information will be very greatfully received, as i've got a 3hour set on UPFRONTDANCE.NET comming up on Wednesday!!!
Big Love to all.
XXX
Big Love to all.
XXX
geposted Sun 14 Mar 10 @ 1:51 am
BTW, I've just checked out the Tecnical support pages and they mention using the cconfig tab to adjust the latencies etc but my BasicVDJ doesn't have that feature....
XXX
XXX
geposted Sun 14 Mar 10 @ 3:06 am
seanna go to hercules,com make sure you download the newest drivers for your rmx .also while on there check out their tips for using djing on laptops some great tips they have also been covered on other topics here.i myself always turn off avg when using vdj.
also try changing in your performance tab latency to auto and uncheck safe mode.check the hardware section on vdj for settings.
also if your not using timecode i dont think you need to use asio.
settings...input none.
output...headphones
. soundcard...rmx(with low latency)
also on tips you will get the right settings for your rmx control settings...ive been using my dell lattitude for a couple of years now and had lots of problems at the start but the tips and tricks here and on hercules and of course the updates in vdj have mine running great for ages
output...headphones
geposted Sun 14 Mar 10 @ 3:41 am
Thanx DJ Staffy... Went there, did that and all is happiness and joy!!! MY GLITCHES ARE GONE!!
Thank you again, you've been very helpfull.
XXX
XXX
geposted Sun 14 Mar 10 @ 6:48 pm
believe me i had it bad also.if it wasnt for the people on here i would have bined the whole lot lol.only thing i will say is make sure after disabling battery in control panel you check your lappy is plugged in lol.ive went dead before.
the more you use your equipment the more you will fix and see how easy it is to solve,
geposted Mon 15 Mar 10 @ 7:21 am
