Hello, I have a technical problem.
In fact i have 2 CDJ 2000, with MIDI USB, is ok on VDJ 6.07 but when i put a cd or USB Key the monitor fix on PC and player, and music continued.
Before is used VDJ with 2 CDJ 400 and no problem.
If somme one and an idea?
Thk by adavance.
Thk by adavance.
geposted Sun 14 Mar 10 @ 11:45 am
i think i have had a similar problem before.
try this..
- close virtual dj
- manually uninstall the usb soundcards in the windows device manager (tell me if you don't understand)
- unplug the two cjd2000's from your computer
- restart your computer
- plug in the first cdj2000 to the OPPOSITE usb port that it was in before. wait until it installs.
- plug in the second cdj2000 to the OPPOSITE usb port that it was in before. wait until it installs
- open virtual dj
try that, and see if it fixes your problem.
try this..
- close virtual dj
- open virtual dj
geposted Mon 24 May 10 @ 7:10 am
