I would like to check before I purchase this software that VST format is supported within OS X.
After downloading the demo I am not able to use VST effects, so I would like to confirm that it is possible before I buy.
Thanks,
TM
Thanks,
TM
geposted Sun 14 Mar 10 @ 7:25 pm
The virtual DJ and not compatible with VST plugins. Maybe in a near future...
geposted Sun 14 Mar 10 @ 9:02 pm
then why the heck does the VDJ site list "VST effects compatibility" as one of the features of VDJ6 pro?
geposted Tue 20 Apr 10 @ 1:36 pm
VirtualDJ does support VST effects.
The windows version supports VST effects. Windows VST effects are dlls and these will not work under OSX. There are OSX VSTs apparently, but I don't know if VDJ supports OSX VSTs.
geposted Thu 22 Apr 10 @ 9:06 pm
