What i need is to create some good looking lists mainly for karaoke /weddings (or video mixing) for my clients.
Excel (or other spreadsheet format) is the way to go i guess but virtualdj can export to m3u...
Did anyone know a simple way/utility or script to convert the standard m3u files from virtualdj in a format that can be imported to Excel ?
Or, alternatively... : to read the contents of a forder (media files, audio/video-including avi-/karaoke) and import them in excel ?
I'd like to use the standard Artist - Title info from filename to create Artist | Title columns..
I'm sure there are many ways to do this but it is kinda urgent for me, so maybe someone here have a good/quick solution.
geposted Sun 14 Mar 10 @ 8:49 pm
Hi . you can use a software that do this for you . i search on google and find this one ..http://www.stgsys.com/fpp.asp
geposted Mon 15 Mar 10 @ 12:35 am
kalimera apopsis
dokimase to programma diprint , (http://www.shareup.com/DirPrint-download-10622.html) (http://download.cnet.com/DirPrint/3000-2248_4-10966913.html).
sou typonei ta periexomena enos folder , kai exei kai arketes parametrous.
enalaktika anoikse thn m3u sto winamp kai apo ekei kane "generate html playlist" kai apo ekei kaneis copy ta periexomena ths selidas kai paste se word
geposted Mon 15 Mar 10 @ 3:29 am
Greetings and good morning:
try with winamp, but please, click "misc", then "generate playlist" but do it with the skin that shows in the picture, then you create lists of songs and then copy and paste into excel, as you mention only drag the file "m3u" into winamp and done
STEP 1
STEP 2
regards
DJ POTTER PRODUCTIONS
STEP 1
STEP 2
regards
geposted Mon 15 Mar 10 @ 10:56 am
It won't be helpful to you at the moment, but the next application I am going to write is going to offer this ability. If you have other "utility" needs please let me know so I can include them in my next app
Yes, it will be available here in the Tools section and freeware (with source code available as well)
Peace,
James
Peace,
James
geposted Mon 15 Mar 10 @ 12:48 pm
Very nice, thank you all,
..no time to test - there is an important event coming and i have to prepare, so i will use my current lists for now.
I'll come back to this thread after a few days.
Thank you again.
Thank you again.
geposted Mon 15 Mar 10 @ 9:24 pm
