i find now that every time i save a sample....and go to load a sample....the samplers becomes blank...for it to come back u have to save about 5 more new samples then it all appears/........whats wrong with this.......its doing a disapearing act.......help plz............
geposted Mon 15 Mar 10 @ 5:13 am
Are you storing your samples on an external drive?
geposted Mon 15 Mar 10 @ 6:33 am
It is a bug.
The samples directory looks empty. Yet if you type the name of a sample, it will load.
If you think you can choose 'all files', all you get are small rectangles in rows.
However, *.* works.
Been going on since 5.x
And yes, the local drive.
However, *.* works.
geposted Mon 15 Mar 10 @ 12:35 pm
it is external drive....
geposted Mon 15 Mar 10 @ 2:51 pm
I've noticed if my samples are on an external drive, I need to re-map the sample location. Unless, I plug the drive in before powering up the PC, and only if the drive extension remains the same.
geposted Mon 15 Mar 10 @ 6:31 pm
So "Samples don't stayed stored?" OR what is the "Fix" I need this to work correctly. I think it has been in production long enough!
These bugs should have been worked out a long time ago. Support needs to step up.
geposted Tue 16 Mar 10 @ 8:33 pm
Now I'm getting fatal shut down..... Slowly not liking this.
geposted Tue 16 Mar 10 @ 9:14 pm
