Hey guys, So I'm using virtual DJ since 2 weeks and i already fell in love with it, Its just great for ''On the GO'' Mixing...
I'm planing on buying the Hercules RMX...
And that i Need help with what cables do i need to hook every thing up with my pc?
geposted Tue 16 Mar 10 @ 6:37 am
You will get all the cables necessar to hook the RMX up to the PC - A USB Cable...
Remember that the RMX is a sound card. You need to connect the RMX to active (powered) speakers or an amplifier - even a home HiFi will do.
To connect the RMX you will need either phono (RCA - red/white) cables or 1/4" jack leads. If you are using professional equipment (DJ Amp or high output active speakers, then you should use the jacks. For a home stereo, PC speakers or even a DJ mixer you should use the phono connections.
These are the only leads you will need to get going.
Cheers,
Roy
Cheers,
Roy
geposted Tue 16 Mar 10 @ 9:11 am
Thanks Mate :)
geposted Tue 16 Mar 10 @ 10:00 am
