hello there.im a noob here
i want to know shortcuts for crossafeder and other important shortcuts
the shortcuts provided in vdj is not much..so hope i would receive feedback as soon possible
geposted Wed 17 Mar 10 @ 9:33 pm
Go to config->mappers, select the keyboard from the dropdown at the top, then click the "new (+)" icon at the bottom, then choose a key for the action (you could hit the key first, because it defaults to "learn" mode), then enter the command crossfader_hamster. Just type in crossfader and the script will appear, read what it does and go from there.
geposted Wed 17 Mar 10 @ 9:56 pm
I have a mapping for an Axiom25 midi keyboard if you would like to use for reference, I'm using a korg nano pad now though, its much better!
geposted Wed 17 Mar 10 @ 11:18 pm
Have you tried 'crossfader' ? ;)
As you type in the mapper window, possibilities are listed. There is also a wiki article here.
geposted Thu 18 Mar 10 @ 6:22 am
there's about 80 default shortcuts .......not much ?
geposted Thu 18 Mar 10 @ 3:57 pm
