Forum: Old versions
Topic: My Working Mac Setup 2011 edition - Page: 3
Look great! the 13mbp is awesome.
wide angle view of the "stage"
Here\'s my little set up:
Another view:
How u like that VCI-300 ?? I have a Hercules RMX and does the job, but I'm looking for a controller more fun to use. Do you recommend it?
I'm really not looking for anything too bulky to travel with
I like it ok, I'd much rather use the ns7, my vci is collecting dust currently I should put it on ebay.
stlaurents wrote :
picture taken with camera phone, will upload some from my actual camera tonight. Made some changes to my rack..drilled two holes upper left corner for the power supply and USB cable for the HC4500.
Stlaurents: question about your case - is the laptop platform stock or an addon - it looks pretty slick!
I had an odessy type holder that was one of the first adapted to my old case to just slide in but that's not an option on the new (read larger case).
Looks good!
Hey guys, here a couple of pics from a gig I did in Mauritius sept 2010.
Running my mac and m-audio controller with vdj
need help putting key code on to computer for the new pro 7 on my mac pro
Here's mine with two decks...
And here's with four decks...
what settings do you use for your mac i gave up on vdj cuase I cannot get it to run right pc nor mac with ns7
Hi all you dj,s this is my system that i use with Virtual dj i love virtual dj way better then serato which i had prior serato is very limited to alot of things .Virtual Dj is better then serato my opinion and em a Club Video Dj and my Denon 3700,s with my Pioneer Djm-800 and Macbook pro work excellent with Vdj i love it here is i pics of some of my gear .
'Can't view your photos, Buddy. Try to reduce the size. This happened to me before too and I used photo editing software (Zoom Browser - Canon) to edit and adjust the size of my pictures. There might be some other ways, but that's how I did mine.
Goodluck!
I don't know if your message is for me but I will try to give an answer.
I run VDJ 7.0.2 with Mac OS 10.6.4 (both on Imac and MacbookPro).
Why give up easily? There's a lot of DJs here who could help you. Just try to research more on the forum and make friends with somebody who runs the same units as yours.
Here's one of the links you could start with...
https://virtualdj.com/forums/140987/General_Discussion/virtual_dj_with_ns7_-_how_well_does_it_work_.html
goodluck!
ask and you shall be given
- 15" MacBook Pro (2.53 GHZ Core 2 Duo, 4Gb 1067 MHZ DDR3)
- Mac OS X Snow Leopard 10.6.6 & Virtual DJ 7.0.2
- Denon DN-X1600 (latest firmware v2000)
- Xone:1D
Works like a charm.
Imac 24"(3.06 ghz/ 500gbHD/ 4gb RAM)
2 Denon DNS-3700s
REI mixer with sampler
2 Mackie HD1521 powered mains 700w each
2 Cerwin Vega 21" powered subs 1200w each
(Room was too small for 2 subs)
Dr. Dre Beats HD Headphones(white)
DJ Cyder wrote :
I'm having issues with my mac And my NS7FX. I'm using a Macbook Pro core duo 2, 4gb of memory, and running Snow Leopard 10.6. Can you offer me some support on how to set up everything. The Issues that I'm having is that the song sound like if they are singing under water!
hold down cue then press play, should solve it till the next update.
75%
