i downloaded a skin 4 vdj 5.2 and nothing change.where did it go what do i do
geposted Fri 19 Mar 10 @ 12:48 am
4 get it im getting vdj 6.0.7 . this what the pros use......
geposted Fri 19 Mar 10 @ 1:35 am
To answer your original question, the LE version that comes with the RMX is restricted to the RMX skin.
You're already getting Pro I see, so make sure you take advantage of your huge discount and then you'll be able to download and/or even create your own skins...
Welcome to the Pro club...
Roy
Roy
geposted Fri 19 Mar 10 @ 12:07 pm
RMX is restricted to the RMX skin,If That Work Well For You Then That All You Need(LE RMX) One Skin
geposted Fri 19 Mar 10 @ 6:20 pm
