Does anyone know if it is possible to control both virtual decks via single turntable using time coded vinyl?
geposted Fri 19 Mar 10 @ 3:03 pm
Yes it is very possible. It is how I DJed for my 1st 2 years.
geposted Sun 21 Mar 10 @ 10:14 am
if your only using one table. make sure your settings are on TMC one of course. every time when you load a new song on a deck your 1st or 2econd deck shout be highlighted. your turntable should automatically corraspond with your desired deck.
what i do is just reposition the stylus and it should work fine.
geposted Mon 22 Mar 10 @ 6:52 pm
