When we try to play the music, we hear a annoying sound trough the needle, but not through the speakers. Is there a way to reduce this noise. Software and time coded vinyl works perfect, only this sound through the needle will not go away. (a kind of high frequency sound)
Greetings
Arnaud
Greetings
Arnaud
geposted Sat 21 May 05 @ 3:24 pm
this sound is unavoidable all records when played on your decks will make a sound, the sound you hear off the needle is what is goin into your pc/speakers, its just more noticable with the tcv's as it is at such a frequency
geposted Sat 21 May 05 @ 3:57 pm
ok.. but it's very loud....
geposted Sat 21 May 05 @ 6:46 pm
turn ur speakers up so u cant hear it ;D, i av the same problem lol
geposted Sat 21 May 05 @ 8:04 pm
try reducing your needle pressure abit, the more you take off the less you will hear
geposted Sun 22 May 05 @ 6:25 am
hehe ok will try this..
Thnx for the support
geposted Sun 22 May 05 @ 4:38 pm
Zero's solution might not help that much :( note that the anoying sound is Acoustic/non electrical!
no offence against DJZero, but I think KUES's solution is a Much better idea :D (ROFL)
geposted Mon 23 May 05 @ 2:55 pm
