hi i have an error in my sound drive and i am not sure how to fix it, can someone please help me?!?!?
Thanks
Thanks
geposted Fri 19 Mar 10 @ 6:41 pm
Use app zapper to remove vdj then reinstall that should take care of it.
geposted Fri 19 Mar 10 @ 7:14 pm
app zapper is not working on my computer, ive also trieddeleting all virtual dj files and apps and then re-installing it and it doesnt work. anything that con be done please tell, i have a gig tomorrow night and i cant bail on it.im using the hurcules rmx by the way
thank you
thank you
geposted Fri 19 Mar 10 @ 8:48 pm
well another program you can use is
called appcleaner
if that one fails you need to go to your
/Users/username/Library/Preferences
look for all the com.atomixproductions.virtualdj.plist
files and delete them all, then make a new install of the latest vdj from your download center.
called appcleaner
geposted Fri 19 Mar 10 @ 9:34 pm
Hello,
If you are in Mac OS 10.5.7 or higher, you should use Hercules drivers 1.77.
http://ts.hercules.com/download/pub/webupdate/DJCSeries/DJSeriesInstall_1_77.pkg.zip
You should not report a technical problem without detailing your technical configuration, as one cannot guess it.
Example of technical details: MacBook 5.1 - Mac OS 10.5.5 - Core 2 Duo 2.2 GHz - 2 GB RAM - VirtualDJ 5.2.2. DJC - DJ Console Rmx with driver 1.77 - DJ Console Rmx plugged and powered by Macbook first USB port on left, the port which is close from the mini display port.
geposted Sat 20 Mar 10 @ 7:20 am
i use appcleaner, delete all components of vdj , reinstall the vdj and again: drive error
but since january i use normally both equipments. before I used only the traktor, no dj controller, Saturday again so I used the traktor and it worked normal, now i try to use vdj + hercules rmx has this problem.
Big thanks for yor help
NZ DJ from Brazil - macbook 4.1 - mac os 10.5.2 - 2.4 Ghz Intel Core 2 Duo - 2 Gb Ram + Hercules DJ Console RMX
geposted Tue 30 Mar 10 @ 8:50 pm
you really need to be running osx 10.5.8 on that machine click the apple logo in the upper left then do all the updates.
geposted Tue 30 Mar 10 @ 9:34 pm
