I accidentally removed a song from the search facility database. I need to reinstate this song however to the search database. Does anyone know if there's an easy way to do this?
Put another way, how can one view a list of the files removed from the search function - and then modify this list, if needed?
Thanks in anticipation.
Cheers
Barry
Cheers
Barry
geposted Sun 21 Mar 10 @ 7:05 am
If you only removed it from the search function. Just go to the
folder that contains the song, and click (on the folder)add to search database.
Your missing song should reappear.
geposted Sun 21 Mar 10 @ 7:57 am
You might give this a try:
Create a filter folder with the following filter:
inSearchDB=0
Thank you,
Robert Pfeifer
Pifemaster Productions
www.pifemaster.com
inSearchDB=0
Thank you,
Robert Pfeifer
www.pifemaster.com
geposted Sun 21 Mar 10 @ 8:06 am
Problem fixed!
Thanks for your help, guys.
Bye for now.
Best wishes
Barry
Bye for now.
Best wishes
Barry
geposted Sun 21 Mar 10 @ 9:36 am
