Hi there,
I am trying to run Virtual DJ 6 and Mixmeister Fusion simultaneously on the same laptop. I have two controllers connected - a Hercules RMX (for VDJ) and an EKS Otus (for MM Fusion).
Everything works fine, except that the Otus controls BOTH VDJ and MM Fusion. Despite having selected the RMX in VDJ options, it still responds to the Otus as well. Is there a way I can tell it to completely ignore the Otus?
Thanks,
Steve
Thanks,
Steve
geposted Mon 22 Mar 10 @ 8:15 am
VirtualDJ v6 will automatically detect and use all supported devices that are connected at start-up.
The only way you could do the above is to connect the RMX only and start VDJ. It will only detect the RMX.
Next connect the Otus and start MM Fusion.
geposted Mon 22 Mar 10 @ 1:16 pm
That sounds like a workable solution. I have to connect the Otus each time I use it anyway. I'll give it a try...
Many thanks,
Steve
Many thanks,
Steve
geposted Mon 22 Mar 10 @ 3:03 pm
