Is it possible to use vdj 3.4 and sl1 in one external hd with all the setting and bpm for both programs? And if so how can I set that up?
Thanx. Dj la pela
Thanx. Dj la pela
geposted Mon 22 Mar 10 @ 1:25 pm
VirtualDJ v3.4 will only use the information stored in its own database. It does not support ID3 tags.
If you upgrade to VirtualDJ v6 https://virtualdj.com/buy/, then you will be able to take advantage of ID3 tags. By correctly tagging your songs, the correct information will be available to both programs. A utility such as Tag&Rename can assist with this.
geposted Mon 22 Mar 10 @ 1:47 pm
thank you very much, i will try that
geposted Tue 23 Mar 10 @ 10:52 am
