Just wondered what was the best os for virtual DJ and using it for video work
is there any advantage to moving to windows7 instead of xp
Regards
Regards
geposted Mon 22 Mar 10 @ 9:50 pm
Honestly, It's my understanding that VDJ was written for a 32 bit operating system utilizing the Direct x 9 for video.
The old adage, if it's not broke, why fix it comes to mind.
jmho...
jmho...
geposted Tue 23 Mar 10 @ 12:17 am
If You got a new Pc or Laptop, then you can think on Windows 7. If you already have XP, you can stay with XP. If you try new OS in an old PC that comes with XP, it could be not good to upgrade the OS.
VirtualDJ Pro runs in PCs Windows XP, Windows Vista and Windows 7 32 or 64 bits (or in Mac OS X).
geposted Wed 24 Mar 10 @ 10:08 am
i am debating if i should upgrade to 7.
geposted Wed 24 Mar 10 @ 8:15 pm
I have just installed Windows 7 Ultimate on a new PC, not for use with virtual DJ!
Windows 7 is amazing and far better than xp, but there is lots more going on behind the sceens than in xp
my thoughts is virtual DJ is a workhorse (toolkit) for DJ's so why over complicate the situation, what ever PC you use for DJing, needs minimal services running in the background, and the least amount of crap installed, etc. to alllows virtual DJ a fighting chance of working smoothly !
If it ain't broke dont' fix it
If you are keen on going down the windows 7 route then will you needs lots of high end hardware to make it work correctly, make the system as high spec as you can !
thoughy I feel virtual DJ will work equally the same in windows xp with a lot less spec of hardware
just my thoughts
just my thoughts
geposted Wed 24 Mar 10 @ 8:48 pm
i have vista right now, which doesnt help haha
geposted Wed 24 Mar 10 @ 8:53 pm
Your a very brave man !!!
I put Vista in the same leauge as Windows ME
The both should have never hit the shops / public, it took ages for vista to be come stable
I guess its Microsoft using as all as Guinne Pigs
geposted Wed 24 Mar 10 @ 9:04 pm
so i should switch then
geposted Wed 24 Mar 10 @ 9:10 pm
I would say yes for going from Vista To Windows 7, its a no brainer
Windows 7 is built the way Vista should have been...
Still not sure about going from XP to Windows 7 ???
Regards
Regards
geposted Wed 24 Mar 10 @ 10:14 pm
I read in a Microsoft information something like this "if you already have Windows Vista, you won't see to much difference in using Windows 7... If you work With Vista stick with Vista, Windows 7 would not give you to much more than Vista SP2 already does."
So far, Windows 7 is the Microsoft option to replace Windows XP as Customer option in newer systems. So if you already have an old PC with XP working, don't change it. If you need more, buy a new PC or laptop, it would come with Windows 7...
If you already have Windows Vista and wnat to try Windows 7, you can do it, but If you remove your SIDEBAR from Vista and do some tricks, you would work like you were in 7.
Regards,
Regards,
geposted Thu 25 Mar 10 @ 2:11 pm
thanks
geposted Thu 25 Mar 10 @ 2:13 pm
Everyone should go 7. Better driver compatibility, and everything is going to win7
geposted Fri 26 Mar 10 @ 2:32 am
yeah i agree with the above post that says "stick with vista"
if you already have it, you arent gonna see much difference with 7
cause vista is actually stable now
and 7 is new, so it will probably have a ton of updates before sp1 for windows 7 comes out although it probably wont be as bad as vista since vista was basically beta for 7 like ME was beta for 2000
lol
so if you already have it and like it keep it, 7 still has just as much background crap in it as vista.... just probably need new drivers for 7 since it is a new OS
id say if you wanted to improve performance from 7 or vista, you could always downgrade to xp (which is something i might do one of these days)
since xp uses up less resources and has lower requirements to run it at optimum level than vista and 7
my 2 cents anyways
lol
my 2 cents anyways
geposted Fri 26 Mar 10 @ 7:05 am
hmmm, back to square 1, haha
geposted Fri 26 Mar 10 @ 10:53 am
windows 7!!! just my .02
I always had probs with Vista and ended up going back to XP.. When I upgraded to 7 I set up to dual boot in either 7 or XP
but.. if you're running fine right now in Vista.....
geposted Fri 26 Mar 10 @ 3:43 pm
shouldnt 7 be faster than vista?
geposted Fri 26 Mar 10 @ 3:58 pm
wouldnt suprise me if it wasnt according to what i had written
geposted Sat 27 Mar 10 @ 3:16 pm
right
geposted Sun 28 Mar 10 @ 12:00 am
I'm using American Audio 14 MXR with a cutom VDJ program that is mapped for this mixer. My OS is Win 7 Pro (64 bit). My problem is, once I input my settings on CONFIG, they do not stay saved. I have to close the program and sometimes have to power down the computer, unplug the mixer from the computer. Start the program back up, plug the USB from the mixer back to the computer.
ANY SUGGESTIONS! I have no other problems, but just want to have my settings to be the same even after shutting down.
geposted Fri 13 Sep 13 @ 8:33 pm
Starting vdj as admin...?
geposted Sat 14 Sep 13 @ 2:06 am
