I have a sneaky feeling that my plater is covered in wax/ polish.
I went to clean it with a damp sponge and the water just beaded. Obv not what i'm wanting. I'm getting to much slip atm.
I was wondering if i can put the platter is a dish washer so that the chemicals would wash off the wax/ polish? I would only put it on a medium temp as it may cause it damage.
Thanks
Thanks
geposted Tue 23 Mar 10 @ 2:27 pm
Try one of those copper pan scrubbers or a brillo pad. Rubbing alcohol or water and bleach may work well too , as they should dissolve the wax a little. I guess the dishwasher couldn't hurt as the platters should be all aluminum so they shouldn't rust, but as a precaution get them dry as soon as possible. I think the real question is, why is there wax on there?
But anyways, hope that helps.
geposted Tue 23 Mar 10 @ 10:33 pm
Hi
You need a chemicle called siroflex solvent cleaner, I use it all the time for all sorts of jobs mainly on plastics, it removes stains, marks etc.
It will 100% clean off any wax / oil, then use the siroflex window cleaner, again the best window cleaner I have ever used for a final clean up
google it, you should find it at any comercial outlet
Hope this helps,
Kind regards
Hope this helps,
Kind regards
geposted Wed 24 Mar 10 @ 3:45 pm
http://shop.upvcnow.com/solvent-cleaner-25-p.asp
here is a link to this cleaner
geposted Thu 25 Mar 10 @ 5:54 pm
