last night i was working on a new mix and today when i came home from work i wanted to continue with it , but when i started it all up i couldnt get any sound from my speakers , tried to reset all the cables but still nothing it would awesome if any of you can give me a helping hand on getting this fixed
geposted Wed 24 Mar 10 @ 7:59 pm
Assuming you checked all cables and volumes. Close all open programs. You may have something else that is using the sound card (like iTunes, Win amp, etc). Also check to see that VDJ is configured for you sound card.
geposted Wed 24 Mar 10 @ 8:14 pm
ya i checked all cables and such reinstalled my sound card drivers , and still is sittin on 0% quality i just find it wired how i havnt touched it since last night and now it wont play :(
geposted Wed 24 Mar 10 @ 8:55 pm
Try to select another soundcard and check. If you get VirtualDJ working, return and change the selection to the sound card you want to use.
geposted Wed 24 Mar 10 @ 11:18 pm
still nothing i can use my maya 44 soundcard on windows media player but i cant get it to work on VDJ i have uin hooked and re hooked up my setup a lot but when i hit the start button on my tables it does nothing but spin the vinyl it wont even show a play icon at the top of the screen so any advise would be great PLZZZZ
edit : both tables say silence btw
geposted Fri 26 Mar 10 @ 5:47 pm
everything up and running thanks everyone
geposted Fri 26 Mar 10 @ 7:44 pm
Glad to hear you are now ok. Enjoy!
geposted Sun 28 Mar 10 @ 2:43 pm
