i have a numark cdn95 on rear panel of main unit it has 3 rca outputs 2 for audio and 1 for video the sound transfers fine to my pa however the video displays a black screen with green lines thru it when i attempt to play cd+g cds in the player i have a quick start manual that gives info but is not helping my problem anyone have a fix for my problem
geposted Fri 26 Mar 10 @ 11:56 pm
Nope. No fix. The CDN95 doesn't have a video-out. The connector you're referring to is a coaxial digital out. This also means that playing CD+G will only give you sound.
geposted Sat 27 Mar 10 @ 6:46 am
