Hello!
I still have problems with playing FLAC format files.
I have installed the OGG codec pack and i have enabled FLAC under VirtualDJ Codecs, but it still gives me an error.
VirtualDJ 6.0.7
Windows 7 Ultimate 64bit
Cheers!
VirtualDJ 6.0.7
Cheers!
geposted Sat 27 Mar 10 @ 5:20 pm
It's very simple. Go into codecs, click the green plus, add the "flac" extension and use the video decoder. Click ok and it will work.
geposted Sat 27 Mar 10 @ 11:09 pm
I tried both the audio ones and the video ones, most of em say an Error but some do load it but the audio is all messed up.
geposted Sun 28 Mar 10 @ 4:23 am
There are two options for FLAC; you can use the Internal Audio Decoder, or install OggCodecs as you have done and use the Windows Media Player Audio Decoder. I personally use the latter. You also need to make sure that the OggCodecs decoder is the default FLAC decoder on your system.
It works perfectly; a large amount of my music collection is in FLAC.
geposted Sun 28 Mar 10 @ 7:15 pm
It did work, but now the audio is messed up(song is right but the speed is very slow and it sounds like the music is in "bullet time")
geposted Fri 02 Apr 10 @ 1:58 pm
