Was wondering why when I double click on the larger window for video I do not get the larger preview window when I'm running karaoke? I can do this when running videos, or am I missing something? any help is appreciated. just starting to fool with karaoke. Thanks Al Rudy
geposted Sat 27 Mar 10 @ 6:19 pm
Any response would be helpful, thinking about using tonight if i can get the large preview window to work I could have someone sing using my monitor. thanks
geposted Sat 27 Mar 10 @ 7:14 pm
Select your video card from the drop down tab in config/video
Also you can stretch the window, the expand option doesn't work.
geposted Sun 28 Mar 10 @ 7:19 am
Thanks for your response, I kind of figured something out the other night, looks like I have to have the karaoke effect activated to be able to get the large preview screen to open up for me, and yes I did know that you can stretch the window to make it bigger because I've done that with videos. It's just that I'm running 2 HDMI signals to 2 progetors and when I do happen to do a karaoke song I would be using my monitor in front of me. thanks for your help, any other sugguestions appreciated! Al
geposted Tue 30 Mar 10 @ 7:39 am
When you select your video card in config/video from the drop down it should auto fit your external screen/monitor/ projector - whatever
geposted Tue 30 Mar 10 @ 8:24 am
