i have a 2nd soundcard , not sure what kind but with asio4all do i still need the original driver for the card, i may have some searching to do ..or will asio4all take care of this as long as XP can detect they type.
geposted Mon 23 May 05 @ 2:07 am
Asio4all is an asio emulator for non-asio card, that will make them work in emulated asio mode for low latency use in VDJ
geposted Mon 23 May 05 @ 2:09 am
so your saying???? yes i still need the actual driver for the card then right? i'm sure i can find one for it
geposted Mon 23 May 05 @ 2:26 am
You need Windows to detect and install drivers for the card...yes..
If windows have drivers that works for the card, use them
if not, you need to get the drivers for the card from the makers of the card
geposted Mon 23 May 05 @ 2:35 am
