Patch team,
Here is another reproducable issue.
Do a search on a song or select any songs in your Lastplay or whatever appears as default to your bootup list of songs in front of you.
Drag one or a few of the resultant songs into the Automix cue box. You are starting to build an Automix playstring.
Then click on any Virtual Folder or Filter to add more songs. Boom... the Automix playlist disappears.
The only way to keep the playlist intact is to turn on Autoplay once you dragged in a couple of songs. It doesn't turn on without any songs in the list.
I don't want the songs to start playing yet either. I just want to build a list for future play.
It would make sense to NOT remove the songs from the playlist when I go to add more songs.
I don't know why the program thinks this is correct behavior. Please another patch fix for x.x.8 please.
Thanks,
JimL
Thanks,
JimL
geposted Mon 29 Mar 10 @ 3:07 pm
I think you go to the config / options and play around with the settings for "AutoLoad Playlists". I think if you choose "disabled" the songs in your playlist will always remain in the playlist window. Whatever the solution is I'm pretty sure it's in the user manual.
geposted Mon 29 Mar 10 @ 4:26 pm
Thanks DizzyRocks. That resolved this issue. I changed option to "Disabled" and now all works logically.
From Manual:
In the Config -> Options tab there is an option for “AutoLoad Playlists”.
The available values have the following functionality:
• Disabled – a contents of the play list are displayed in
the center File Browser panel only
• Always – when a play list is selected in the browser
the contents are immediately loaded to the playlist
• Smart – doesn't change the playlist when you click on a
playlist folder, if the actual playlist has been manually edited
I never loaded a playlist into the autoplay browser. Time to experiment. You nailed it.
Regards,
JJL
geposted Mon 29 Mar 10 @ 11:43 pm
