what is the value for raise n/lower the pitch 1% at a time? for fine ajustments to the pitch slider. this is 4 ver.6
geposted Mon 29 Mar 10 @ 4:41 pm
1% isn't really a fine adjustment.
pitch +0.1%
pitch -0.1%
for example.
pitch +0.1%
pitch -0.1%
for example.
geposted Mon 29 Mar 10 @ 7:18 pm
thank u. i did this and this will change the pitch in like %s of 2 insted of 1%
ex. 98.07 bpm press lower will change to 97.90. insted of 98.06 and so on. i hope this makes sinse.
geposted Tue 30 Mar 10 @ 7:27 am
You can add a shortcut to your keyboard with the following syntax..
[Keyboard key or combination No1] pitch -A and
[Keyboard key or combination No2] pitch +A
The A number is the step that pitch does everytime you press that key. How you calculate number A. Let's say for example that you have set the pitch range to +-8%. Number A for example 0.05=1/20 shows that pitch range will be devided into 16/20=0.08. So if you put pitch +0.05 with pitch range +-8% then the step will be 0.08. If you want the step to be 0.01 then for the same pitch range you should use pitch +0.00625 and pitch - 0.00625.
As you may understand it depends on the pitch range you have selected. If you change the pitch range you have to change the command too.
geposted Tue 30 Mar 10 @ 2:52 pm
I GOT IT!!!!!!!!!!!!!!! THANK YOU.!!!!!!!!!!!!!!! REMEMBER JESUS DIED ON THE CROSS FOR US TOMORROW!!!!!!!!!!!!!!!!!!
geposted Thu 01 Apr 10 @ 9:07 am
