I have Virtual DJ trial & am looking to buy it, however, I cannot map my Radius 3000's on the mac. American Audio provide a midi command file here http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1437&Category=CD_Players&txtSearch=, for mapping your Radius 3000's with Virtual DJ, however that is a windows file not a mac. Anyone know if there is the same file out there just for Mac, if so where abouts can i get it?
geposted Tue 30 Mar 10 @ 10:36 am
You should not need a mapping file. All Radius units (1000,2000, & 3000) are already provided support in the latest version (6.0.7).
Is the trial version not detecting your unit(s)?
geposted Tue 30 Mar 10 @ 11:31 am
It only detects simple MIDI wrapper & not the Radius 3000. Even though when I click off the 'show only connected devices' i can see the Radius 3000's on the list.
geposted Tue 30 Mar 10 @ 11:34 am
No, the trial version does not recognise them at all. Can't figure out why at all.
geposted Tue 30 Mar 10 @ 2:53 pm
Are you running the latest v6.0.7 trial? https://virtualdj.com/download/trial.html
geposted Tue 30 Mar 10 @ 3:18 pm
Yes, that is the one I am running, but it does not seem to want to recognise the devices.
geposted Tue 30 Mar 10 @ 3:41 pm
I dont know whether i'm missin out something silly here. I had the trial version on PC & it didnt work with my decks until I downloaded the Midi command file of the American Audio website, so i presumed i must do the same for the Mac, but its not possibleas the file is not compatible.
geposted Tue 30 Mar 10 @ 5:02 pm
Sorry ... buy I know you are not running the latest Mac trial. The units work under the latest Mac trial as I have all three units that I mentioned earlier and are recognized just fine. None of the units were functional in VirtualDJ prior to version 6.0.5 which added the 1000 and 3000 units. In ver 6.0.7 we added the 2000.
So please uninstall all versions you have. Delete the Documents/VirtualDJ folder and download the latest Mac trial version.
geposted Wed 31 Mar 10 @ 12:43 am
is for radius 1000
geposted Fri 06 Aug 10 @ 11:37 pm
I need download the software radius 1000
geposted Fri 06 Aug 10 @ 11:39 pm
is for radius 1000
geposted Fri 06 Aug 10 @ 11:41 pm
Download the trial here - https://virtualdj.com/download/trial.html
geposted Sat 07 Aug 10 @ 8:35 am
