I know this has been discussed but I was unable to find the info.
What needs to change so my jogwheels are less sensitive? I would much rather they behave like true jog wheels. I don't want the track to stop when the wheels get bumped. This used to be configurable within VDJ in my LE version.
geposted Tue 30 Mar 10 @ 9:07 pm
if you are using 6.07 then click options config then you can set all 3 right from vdj
sorry about the mac ss but its the same on pc.
geposted Tue 30 Mar 10 @ 10:27 pm
In VirtualDJ Pro, you can toggle the jogwheels to CD mode by going to CONFIG -> Options and choosing this.
In CD mode, they will pitch bend when the song is playing, making an accidental bump far less noticeable.
geposted Wed 31 Mar 10 @ 1:16 pm
Ahha, thanks to you both. For some reason I remember reading about needing the registry tool to adjust this in the newer versions.
(too many tokes, I guess)
geposted Wed 31 Mar 10 @ 1:37 pm
