Hi all.
I am relatvely new to VDJ and think it is an excellent bit of kit. I currently use it for audio and music video DJing and I was wondering if there is a way of getting a certain video to play whilst you are playing a song which you don't have a video for.
In case i'm not clear, I might for example play a Usher-Yeah.mp4 and then mix it to B2K-Girlfriend.mp3. As the later isn't a music video, I would like another video to play instead of just displaying a blank black screen.
I have an advertising video file for the club that I work in that I want to play during the audio files.
Any ideas if this is possible (which I am sure it is) and how to do it?
Thank you,
Steve.
Thank you,
Steve.
geposted Wed 31 Mar 10 @ 7:33 am
You can have a slide show, clip banks, camera and a few other options play when using audio files. Check in the Configure tab and look for the section that says play when using audio files. Make your selection and save. This setting will now play when you use an audio file instead of video.
Angel S
I hope this help
Angel S
I hope this help
geposted Wed 31 Mar 10 @ 8:21 am
djsteviec1981 wrote :
Hi all.
Thank you,
Steve.
Thank you,
Steve.
Look up how to link a video to an audio.
geposted Wed 31 Mar 10 @ 9:15 am
