Hey VDJ community,
Just wanted to see if anyone has managed to minimise or somehow get rid of the whining noise the TT emits when using timecoded vinyl?
Cheers everyone,
alex
Cheers everyone,
alex
geposted Wed 31 Mar 10 @ 11:57 am
Do you have a belt drive TT? Been quite a few years since I used one, but I know worn belts would loosen, start slipping and cause a "whine"
Roy
Roy
geposted Wed 31 Mar 10 @ 4:57 pm
I thought this topic was about something else. I think he's talking about the actual noise from the needle moving over the record, not much we can do about that.
geposted Wed 31 Mar 10 @ 6:29 pm
thats the timecode signal, it will always be there
geposted Wed 31 Mar 10 @ 8:08 pm
Is it coming trough your speakers? In that case you have to mute your troughput.
geposted Thu 01 Apr 10 @ 3:41 am
Can you clarify what you mean? Does it get louder when you increase volume? Is this a ground loop hum? What happens if you change mixers?
geposted Thu 01 Apr 10 @ 10:37 am
just to clarify as someone rightly said above the its the noise the actual turntable emits when playing a timecoded vinyl, it's like a whiney hum, which is a tad irritating - I thought I read somewhere you can limit it, but I suppose it really is just the needle playing the strange vinyl!
Nothing to do with ground loop or speakers - at least that would be an easy fix!
Cheers gang.
Cheers gang.
geposted Thu 01 Apr 10 @ 3:00 pm
You can't limit or disable it. :) If you listen really closely to your turntables on a regular vinyl you can also hear the song playing. :)
geposted Thu 01 Apr 10 @ 3:16 pm
Cheers gang.
Cheers gang.
If you can hear that whine then you really need to turn your system up, lol!
geposted Thu 01 Apr 10 @ 5:03 pm
