Delta 66 or maya 44? wil the Delta 66 work with vdj (it does support ASIO2) get paid on 24th vdj is on my shopping list :D:D
geposted Mon 23 May 05 @ 12:54 pm
Some people are using the Delta 66, however the Maya44 USB is more widely used and IMO the easiest to setup and configure. Are you looking for just outputs or are you planning to use TCVs or TCCDs.
cstoll
cstoll
geposted Mon 23 May 05 @ 2:24 pm
Kues is right. Maya 44USB has proven it's quality and stability in use with Virtualdj (especially the TCV-users).
but on the other hand, the Delta 66 does support Asio2, i'm pretty sure it will work too in low latency TCV-mode.
I also use the Maya 44usb for TCV. i never had problems and the sound quality is perfect. I would recommend the Maya44usb ;)
geposted Mon 23 May 05 @ 3:13 pm
