i wud wanna ask if there is any loss in quality of sound if i use 4.1 soundcard to relay one o/p to headphone and other to main speakers? since its gonna be output in the mono format? cos i dont have two soundcards....help me..i know it cant be done in the demo..just wanna make sure there are no probs, before i purchase the software..HELP! thanks! this software rocks! my talent is finally saved!
geposted Mon 23 May 05 @ 4:28 pm
I post it the answer in your other post. Here is the answer.
If you don't have 2 cards you can use your 4.1 to have the sound of your VDJ to de Front L&R and the Rear L&R to listen your phones. Do the same If you want to use your VDJ with an external mixer, but select the correct option on the Config->Sound Cards of the VDJ.
geposted Mon 23 May 05 @ 10:41 pm
